Author Topic: testing 69 camaro headlight switch  (Read 1803 times)
bad69 396
« on: July 26, 2020, 03:46:48 PM »
no dash lights or console lights, i did a ohm multimeter test of switch for dimming the dash,pulled to park position and turned knob to left for brightness and number read a 4,turn to the right for dimming and to turn off it read -1, well i think that is the opposite readings for both,bright to left should be -1 and right to dim should be 4 am i correct on this? thanks
