Author Topic: cowl tag 12437 used for both coupe and convertible?  (Read 9842 times)
mmmiller
« on: March 29, 2007, 08:40:21 PM »
was cowl tag number and vin number 12437 used for both the coupe and convertible? or does 12437 indicate coupe only? and 12467 convertible only?
thanks
Re: cowl tag 12437 used for both coupe and convertible?
« Reply #1 on: March 29, 2007, 08:49:05 PM »
Please read this link for the answer to your question:
http://www.camaros.org/numbers.shtml#VIN
mmmiller
« Reply #2 on: March 29, 2007, 10:05:23 PM »
Thanks. I did see the decoding chart but I have a 1967 camaro with a "37" trim tag and it is a very nice clean convertible that has not been cut or altered. It looks like the original cowl tag. I also visited another site that indicated that "37" could represent a coupe or covertible.  Is the only explanation that someone changed the trim tag???????????   Any help is much appreciated. I am new to this and so not very knowledgable (not yet)
Thanks again for the reply.
« Reply #3 on: March 29, 2007, 11:17:25 PM »
Mike -
Could you post some good photos of your trim plate here?  There are many experts on this forum who could tell you if the trim plate has been replaced or not after looking at it.  They just need good quality, in-focus photos to do so.
« Last Edit: March 29, 2007, 11:19:51 PM by 1968RSZ28 »
mmmiller
« Reply #4 on: March 29, 2007, 11:26:43 PM »
Good deal-thanks for your replies. I will post good pics when I get the car back from inspection.
KevinK
    • Hudson Valley Camaro
« Reply #5 on: March 30, 2007, 12:19:14 PM »
 ...note there is a difference with the 'ST' numbers on the COWL/TRIM tag vs. the VIN tag......
mmmiller
« Reply #6 on: March 30, 2007, 02:42:23 PM »
thanks,  my trim tag is as follows:
O3G
ST   67-12437  NOR  92058
TR   756-H           C-2   PAINT
W   2R   3L
5Y
I did'nt understand how I have a convertible when 67-12437 inicates a hardtop and not a convertible.
Any info would be appreciated.
« Reply #7 on: March 30, 2007, 03:31:21 PM »
Mike, it could be a mistake. Although rare, Trim Tags have been known to have incorrect information on them.
Another possibility is that the tag could have been changed. What's your VIN? If we compare the 03C (?) build date on the tag (recheck your number. you have 03G. That would indicate the 7th week of March and that's not possible!), to the known assembly dates of the VIN's, we can see if it lines up.
A final possibility is that you have a reproduction tag. Post a picture and we can look at that as well.
mmmiller
« Reply #8 on: March 30, 2007, 03:48:25 PM »
thanks. It is 3C. I will check my VIN and also post a pic of the trim tag when I get the car back from inspection.
Thanks again for all the response-speaks highly of this board.
Mark
« Reply #9 on: March 30, 2007, 04:09:16 PM »
Its not a production error, the tag indicates the car has a bench seat, which was not available in a convertible.  so the tag has either been swapped, its a fake, or someone made a convertible out of a coupe (that would be really bad).  Can we assume the VIN starts with 12467 (or 12367) so we can rule out the coupe to convertible conversion?
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
