Author Topic: 69 RS Camaro hideaway headlight Vacuum tank  (Read 3860 times)
67GTX
« on: June 02, 2020, 10:55:55 PM »
I have two tanks, 1 has two vacuum ports on the tank and the other has one.... the brackets are different and in different locations....
I'm Restoring my 69 SS/RS Pace car Convertible tribute car, and would like to know which vacuum tank is correct.
Can anyone help me?
Re: 69 RS Camaro hideaway headlight Vacuum tank
« Reply #1 on: June 02, 2020, 11:58:00 PM »
The 2 port is '68. Changed to 1 for '69.
Don't even bother trying to re-use an original valve. Get the OER repro.
67GTX
« Reply #2 on: June 05, 2020, 11:37:28 AM »
Thank you for your info,I am having trouble trying to find the hole in the firewall where the groment that the 2 vac lines that go
to the headlight switch,it doesn't show in the assembly manual either,can you please help,thanks
Dusk Blue Z
« Reply #3 on: June 05, 2020, 11:56:04 AM »
The grommet for the two vacuum lines going to the headlight switch is to the left of the grommet with the two wires for your cowl induction hood.
1969 Z/28 Legends Certified
1969 Z-10 350 4 speed
BillG
« Reply #4 on: June 05, 2020, 11:56:35 AM »
You said the car is a "tribute".  Was it originally a Ralley Sport?  If not the factory hole will not be there,
Bill Garrett
67GTX
« Reply #5 on: June 05, 2020, 02:15:56 PM »
Yes it was a RS /SS convertible car,just paint was reverse of the pace car,orange /white stripes
