Author Topic: C.I Exhasut Manifolds, paint or no paint  (Read 11533 times)
hgger69
  • Hugger orange rules!
    • Håkans Motorsida
Re: C.I Exhasut Manifolds, paint or no paint
« Reply #15 on: June 08, 2020, 05:58:47 AM »
Yes, that's the very one.
Great!
And it wouldn’t be a problem to add this despite the manifolds is used but fairly new and already mounted?
Hakan from Sweden
www.hakansmotorsida.com
« Reply #16 on: June 08, 2020, 12:06:08 PM »
 I applied mine while the manifolds were mounted on the motor. The foam brush has a tapered straight edge that makes applying it along seams easy. If there are scales of rust then I would remove and clean them first. It goes on watery and you can apply as many coats as needed. Unlike paint, which can bridge texture, graphite will not because it flows into the metals pores.  It will look dark at first due to being wet but after a couple of engine cycles it will lighten just a little.
hgger69
    • Håkans Motorsida
« Reply #17 on: June 09, 2020, 06:17:29 AM »
Perfect Mike, I’ll try this during the winter!
Hakan from Sweden
