Author Topic: Correct size T bolts for leaf springs  (Read 3433 times)
emdoller
« on: May 30, 2020, 06:24:48 PM »
I have a 69 convertible with 5 leaf springs. I removed them in order to install new ones. The T bolts are a bit worn and are about 1.5” in length. I ordered a set for multi leaf and got ones that are closer to 2”. When I look at catalogs they say the 1.5” I have are for mono leaf. I’m fairly sure they are original to the car and fit well.
Can anyone help clear this up?
Everett#2390
  • ^Bess
Re: Correct size T bolts for leaf springs
« Reply #1 on: June 03, 2020, 12:01:07 AM »
I believe the T-bolts are the same length for both mono- & multi-leaf springs because the bottom spring plate meets with the welded spring perch on axle tube.
The plate/perch squeeze the pads and spring for fit.
 I suggest using the OE bolts you have and slightly coat the threads with anti-seize and enjoy the ride.
Check nut every ten miles(?) until your confident they will remain tight, or are tight.
Edgemontvillage
« Reply #2 on: June 08, 2020, 02:04:26 PM »
Original T-bolts are 1.25" and I have not seen a difference between those used for mono leaf vs multi leaf applications.
Untitled by Lloyd Costley, on Flickr
emdoller
« Reply #3 on: June 30, 2020, 11:31:41 PM »
Perfect! Thank you!!
« Reply #4 on: July 01, 2020, 12:51:18 AM »
The ones out of my mono 10 bolt are 1”. The ones out of my 12 bolt multi Are 1.25”
