Author Topic: Correct intake manifold for 1968 L35  (Read 2645 times)
ericisback
« on: May 18, 2020, 11:09:55 AM »
Can someone confirm that the correct intake manifold casting number for a 1968 L35 (325hp) is 3883948?  Thanks for any help.
67 Corvette 427 conv. -  https://bit.ly/2yykRW7
67 GTO 400 conv. - 68 Camaro 396 conv.
69 R-Code Mach 1 - 78 VW Beetle conv.
Re: Correct intake manifold for 1968 L35
« Reply #1 on: May 18, 2020, 02:04:25 PM »
That is the correct casting number for '66-'68 BB/Q-jet according to Chevrolet by the numbers. There is a slight machining difference on a '68; the mounting boss for the temp sending unit next to the thermostat mount was not drilled & tapped. For '68 sending unit moved to the cylinder head.
ericisback
« Reply #2 on: May 18, 2020, 02:45:56 PM »
Got it - undrilled boss.  Thanks!!!
