Author Topic: 9N513117 Muncie M22  (Read 3378 times)
9N513117 Muncie M22
« on: May 11, 2020, 10:09:00 AM »
Muncie M22 complete transmission for sale on ebay.
Main Case: 3925660
Partial VIN: 19N513117
Assembly Stamp: P9M31
Possible VINs: 124379N513117 or 124679N513117
Auction URL: https://www.ebay.com/itm/Rebuilt-Original-GM-1969-Muncie-4spd-M22-Rockcrusher-Camaro-Z-28-ZL1-Chevelle/264726825335
Seller ID: hooked95
Item Location: Red Lion, PA, USA
Seller's Description:
Quote
This is a 1969 rebuilt original factory GM Muncie 4spd M22 Rockcrusher case close ratio trans in excellent condition.The casing still has the original finish and original casing bolts.This trans still retains the original factory GM M22 gear set in excellent condition!!!!!!! all bolt holes intact.The trans has a deluxe rebuild kit including a NOS GM new departure front input bearing and a USA rear bearing,forged syncros,shift keys and springs,all thrust washers,cluster pin and needle bearings,rear input cage and bearings,input nut,shim,bearing retainer and bolt locking straps,shift forks,rear bushing,gaskets and seals.The trans turns over and shifts smooth.The trans is ready to install,just add oil.The main case is 3925660,tail is 3857584 and side cover 3950306.The trans is originally out of a 1969 camaro.It has a 10 spline input and a 27 output shaft.This trans is matching numbers from front to rear for any GM model year of 1969.If you have been looking for a original 1969 GM M22 trans...you just found it.local pick up is welcome.Thanks and good luck bidding.......
