Author Topic: Legends - You don't know jack about Camaros  (Read 9937 times)
hihorse
Re: Legends - You don't know jack about Camaros
« Reply #15 on: May 18, 2020, 07:06:21 PM »
I have only seen the Ryerson & Haynes and the Ausco ( marked AB I believe ) on the A body cars. Not familiar with them used on the first gen Camaros. Thanks for the photos
i have the RH jack from 1968 Camaro, can't find date on it ( should be end of post near seam) , anyone have picture they can post showing date?
« Reply #16 on: May 20, 2020, 04:35:11 AM »
Not sure if you'd like to add this data into the new research topic thread, or start afresh, but there's quite a lot of contributions in this thread: http://www.camaros.org/forum/index.php?topic=13242.0;all
« Reply #17 on: May 21, 2020, 04:05:00 AM »
Tim,
Sorry, I had CRS (can't remember sh1t) and totally forgot that thread. I moved it into the correct forum, updated it, and deleted my topic. :)
Thanks!
« Reply #18 on: May 21, 2020, 08:43:05 AM »
I'm a frequent sufferer of that CRS!
R68GTO
« Reply #19 on: May 28, 2020, 12:27:43 AM »
I'm confused on date codes for jacks.  I have an original 69 jack that has a date of 8M stamped on the rivet.  What date, December of 68?
x66 714
« Reply #20 on: May 28, 2020, 01:11:20 AM »
8M should be Dec 1968. They probably didn't use the letter "I"....Joe
R68GTO
« Reply #21 on: May 28, 2020, 01:35:18 AM »
Thanks Joe.
« Reply #22 on: May 28, 2020, 06:51:08 AM »
I had to go and look it up again, but here's the explanation on GM-produced parts, from the 'numbers decode' section. Presumably the same date coding was applied to externally-supplied components:
Quote
For cast-in date codes on GM-produced iron and aluminum castings (engine blocks, heads, intakes, water pumps, etc.), the letter "I" was used for September, and the last month of the calendar year (December) was the letter "L". For stamped-in date codes on GM-produced components (alternators, distributors, starters, etc.), the letter "I" was not used - "I" was skipped, and "J" became September, with December being "M".
