Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
69 Press. Reg. Valve
« previous
next »
Print
Pages: [
1
Author
Topic: 69 Press. Reg. Valve (Read 2473 times)
DONCZ28
Member
on:
April 19, 2020, 12:14:01 AM »
Brass valve located @ driver side subframe. I noticed that the in and out ports are different sizes. Are there any internal components ? Had to heat fittings to remove lines.
Tweet
Logged
Hero Member
Re: 69 Press. Reg. Valve
Reply #1 on:
April 19, 2020, 12:31:15 AM »
Yes, there is a spring loaded rubber seal inside the body.
You can get a rebuild kit from Muscle Car Research
https://www.musclecarresearch.com/
Unscrew the cap on the bottom and you can get to the internals easy to remove and examine the seal.
If it looks good then just clean out the body and re-assemble.
Here is a link to the internals:
https://www.musclecarresearch.com/kh-multi-prop-valve-autopsy
Logged
DONCZ28
Member
Reply #2 on:
April 19, 2020, 12:51:07 AM »
Thank's Mike for the info.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
