Author Topic: 1968 Camaro Brake warning light switch wire.  (Read 3646 times)
Tinkerr
« on: April 11, 2020, 09:33:58 PM »
The Assembly Manual show the wire for the switch in the distribution block originating from the engine harness. The new engine harness has no such wire am I reading the manual wrong or seeing things that aren't there? Thanks
Re: 1968 Camaro Brake warning light switch wire.
« Reply #1 on: April 12, 2020, 12:56:28 AM »
Where in the assembly manual are u seeing that as I remember that wire internal to the dash area but maybe my memory has gone south. Lol
« Reply #2 on: April 12, 2020, 01:00:32 AM »
It's part of the front alternator/horn relay/voltage regulator etc... harness.
« Reply #3 on: April 12, 2020, 01:20:15 AM »
Sample
« Reply #4 on: April 12, 2020, 02:14:13 AM »
Me bad, read it and missed the key point distribution block as I was thinking the switch off brake pedal. Thanks Ed and Jim
Tinkerr
« Reply #5 on: April 12, 2020, 02:34:16 AM »
My mistake UPC 12 page 158 shows a wire exiting the engine harness and is marked to brake alarm switch. I thought that was the switch on the distribution block. Thanks for the replies Gentlemen.
