Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
Water pump pulley size
« previous
next »
Print
Pages: [
1
Author
Topic: Water pump pulley size (Read 4035 times)
dalekerr
Member
on:
March 20, 2020, 11:12:45 PM »
I have a 67 with sbc motor and I added vintage air. Since adding the air the car runs hot up to 230 degrees while sitting idling after 10 minutes or so. It never gets above 190 while driving at highway speeds. The car has a new 3 core aluminum radiator with shroud, new 7 blade fan and clutch. I noticed that the crankshaft and water pump pulleys are the same size.
I can rev the motor rpm up and bring the temperature down.
My question is would possibly changing the crankshaft pulley to a larger size or putting a smaller water pump pulley solve my running hot while idling issue?
Yes the timing is set correctly.
Opinions please
Thanks in advance
Dale Kerr
Tweet
Logged
Dale Kerr
1967 Y 2 350 M20 12 Bolt Vintage Air
03D
CRG Coordinator
Re: Water pump pulley size
Reply #1 on:
March 21, 2020, 02:47:19 AM »
I'd start with the pulley sizes used with AC vs non-AC cars.
http://www.camaros.org/engine.shtml#PulleySpreadsheet
Logged
Hero Member
Reply #2 on:
March 21, 2020, 04:40:05 PM »
I notice you didn't spec what thermostat you are using, 180 or 165 degrees ? Stock water pump, OE rebuilt or aftermarket ?
Logged
1969 Z11 L48/M35/C60/C06 1949 3100 5wd 235/6
dalekerr
Member
Reply #3 on:
March 22, 2020, 01:41:52 PM »
180 stock water pump.
Logged
Dale Kerr
03D
dalekerr
Member
Reply #4 on:
March 28, 2020, 06:41:00 PM »
Ok I ordered and installed a new crankshaft pulley 7.25 and a new water 6.3 pump pulley today. This seems to have solved my running hot while idling. The car is now running about 10 degrees cooler while driving and idling.
I read on another site about pulley sizes and cooling.
Logged
Dale Kerr
03D
Print
Pages: [
1
« previous
next »
Maintenance
