Author Topic: Cleaning & Lubricating Window/door parts  (Read 3652 times)
joesauer
« on: March 19, 2020, 08:12:42 PM »
Under a shelter in place order, so plenty to time to get an early start on springtime projects.  Decided to replace my 68' standard door panels & clean/lube window & door gears/mechanisms.  50 plus years of gunk.  Any suggestions for the best grease/gunk removal product?   Any recommendations on the best lubricants to use?
Re: Cleaning & Lubricating Window/door parts
« Reply #1 on: March 19, 2020, 08:45:57 PM »
 I've used ZEP Purple cleaner to soak and remove the gunk, then used Mobile 1 synthetic grease to re-lube.
I've seen Gunk engine cleaner used successfully too to clean the parts. This is with all the components out of the door of course.
« Reply #2 on: March 19, 2020, 10:31:56 PM »
I use a “grease stick” . A stiff waxy substance that resembles beeswax
« Reply #3 on: March 31, 2020, 11:47:53 PM »
The grease stick works great on tracks, mobile 1 injected with a rubber tip in the transmissions (gearbox)
