Author Topic: Steel Wheels/SS hubcaps  (Read 7765 times)
gro51
  • 68 SS/RS 350
« on: March 25, 2007, 02:43:28 PM »
I currently have this setup all around:  14 x 6 steel rims with 225 70 r 14 tires.  Here's what I want to do.  I want to get larger wheels and tires for the rear, but I want to still be able to use my SS hubcaps.  Did GM make 14 X 7 rims?  And I'm not talkin' about rallye wheels, just the regular factory steel wheels.  If I can get a couple 14 X 7 rims, what size tires would fit?  235 60r 14?  I have stock front and rear suspension.   Thanks in advance.
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
lcmc
Re: Steel Wheels/SS hubcaps
« Reply #1 on: March 25, 2007, 03:47:17 PM »
Standard 69 SS wheels were 14x7 XT wheels.
Danny
1969 Z/28 X77
Jonesy
  • 1969 Camaro z28
« Reply #2 on: March 25, 2007, 03:56:20 PM »
IF coded wheels are 14x7 steel wheels also found on early 69 LA cars as documented on my Broadcast sheet.
1969 Z28 Azure Turquoise
gro51
  • 68 SS/RS 350
« Reply #3 on: March 25, 2007, 04:03:37 PM »
Thanks Danny and Jonesy.  These are plain Jane rims you're talking about?  In other words my SS hubcaps will pop right on?  I'll stat looking around for a pair.  Any suggestions regarding tire size?  235/60/14?
Joe
Schodack, NY
lcmc
« Reply #4 on: March 25, 2007, 04:31:32 PM »
Joe, yes the XT and IF wheels are both plain jane steel wheels. Hub cap will pop right on. As far as tire size I don't think you would want to go any wider than a 235 on a 7 inch rim. Standard tire size was F70 and I believe a 235 is just a little wider than an F70.
« Last Edit: March 25, 2007, 04:37:08 PM by lcmc »
Danny
1969 Z/28 X77
« Reply #5 on: March 25, 2007, 08:27:50 PM »
