Author Topic: 1st Gen Rear Drum Brake Backing plate  (Read 4337 times)
adamkhan
« on: March 18, 2020, 11:55:28 PM »
I'm trying to figure out if 1st Gen Rear Brake Backing plates are the same for 67-81 F-Bodies or not. GroundUpSS396 lists the above years as the same but Classic Industries & Rick's lists them only from 67-75. Any experts here who can shed more light on this please? Thanks.
rich69rs
  • LF7/M35/Z22/Z87
Re: 1st Gen Rear Drum Brake Backing plate
« Reply #1 on: March 19, 2020, 10:47:19 PM »
Does this help?
Richard
Richard Thomas
1969 RS
KevinW
« Reply #2 on: March 20, 2020, 02:57:42 PM »
I have some rusty ones :)
Seriously, do you have a 70 and newer and need to see if these will fit?
rszmjt
« Reply #3 on: March 21, 2020, 02:33:38 PM »
67-71 Camaro 12 bolt are the same as 68-71 chevelle 12 bolt , 10 bolt backing plates are different as they don’t have the little 1/2 moon shield spot welded on the bottom, however they will fit. FWIW I have made the shields and plug welded them on to 10 bolt backing plates before.
