Author Topic: New - Bryon's axle carrier article  (Read 16040 times)
m22mike
Re: New - Bryon's axle carrier article
« Reply #15 on: March 13, 2020, 01:06:09 PM »
Great info and a awesome article  Byron. Glad you could use a photo of mine.
X66 L78 M22 4.10 Deluxe Threads, PNT 10/10, Red Hockey stripe
x66 714
« Reply #16 on: March 13, 2020, 02:54:32 PM »
Re-read it some more times. Now I know which fill plug to look for on my 68....Joe
olddragracer
« Reply #17 on: March 13, 2020, 04:10:04 PM »
Congratulations on a great report. Lots of good information for anyone trying to understand or work on a 67-69 Camaro rear drive axle. I do have a concern with the naming of the main components. It is my understanding that the housing you see when you look under the rear of car, that contains all the gears and bearings is called the "carrier'. The parts catalogue calls that housing "carrier and axle tube assembly. The housing inside that holds the differential gears is called the "differential case'. The differential case is available with limited slip [positraction] or conventional [open] components.
« Reply #18 on: March 13, 2020, 04:15:47 PM »
I thought the wording was right, but will check things over. Thanks for the feedback!
JKZ27
« Reply #19 on: March 14, 2020, 11:51:38 AM »
Nice work, Bryon.
Is "pinion yoke" used more commonly than "pinion flange"?
John
68 RS Ash/Ivy Gold 327EFI M20
« Reply #20 on: March 14, 2020, 12:40:57 PM »
Yep. Say Propeller Shaft Pinion Flange and Deflector to some people and they might not understand. Pinion yoke is less technical, but more widely understood.
https://www.moserengineering.com/Pinion-Yoke.dept?page=all
fsc66
« Reply #21 on: March 14, 2020, 01:44:30 PM »
Nice Job :)
Thank you,
« Reply #22 on: March 15, 2020, 07:13:02 PM »
That is not the industry accepted use of the terms.
The differential carrier is that which carries the differential gears. Case is often used as an equivalent term.  https://en.wikipedia.org/wiki/Differential_(mechanical_device)
« Reply #23 on: March 15, 2020, 08:58:57 PM »
Some of the terminology confusion comes from the different designs used over the years!
For the Camaro 1st gen differentials, where the differential gears are 'assembled' into the entire case, the 'case' if the carriers.
For older chevys which had a 'chunk or pumkin' that removable chunk 'case' was the carrier.   Same with Ford 9' rears...
adjudimo
« Reply #24 on: March 16, 2020, 06:39:46 AM »
Congrats and Thanks to Bryon and others for the time researching and reporting this information.
olddragracer
« Reply #25 on: March 17, 2020, 07:25:50 PM »
The automotive industry terms for the two major drive axle components used in the 67-69 Camaro are:  "differential carrier" and "differential case". When ordering parts or diagnosing problems on the Camaro rear drive axle the "carrier and axle tube assembly" is usually stated as the "carrier". The component "differential case" is often abbreviated to "diff case". The incorrect use of these terms has caused much confusion when discussing many vehicles including 67-69 Camaro.
BRG Z28
« Reply #26 on: March 17, 2020, 11:50:16 PM »
Can you please clarify if “l” or “H” was used for 1968 carrier date stamping? I heard that “I” was skipped in the alphabet.
m22mike
« Reply #27 on: March 19, 2020, 12:43:37 PM »
Look through this thread at yenko.net. Post 12 has a shot of a 68 unit stamped "I"
https://www.yenko.net/forum/showthread.php?t=159670
« Reply #28 on: March 19, 2020, 08:56:15 PM »
“I” was used for year. And it’s calendar year.
I had one with “I” a while back but the post Mike mentioned was confirmation of its use.
Do you have data which conflicts with that?
« Reply #29 on: March 19, 2020, 09:01:02 PM »
Based on the report and supporting photos is it clear enough to understand?  I appreciate the feedback but you need to realize it’s impossible to please everyone.
