Congratulations on a great report. Lots of good information for anyone trying to understand or work on a 67-69 Camaro rear drive axle. I do have a concern with the naming of the main components. It is my understanding that the housing you see when you look under the rear of car, that contains all the gears and bearings is called the "carrier'. The parts catalogue calls that housing "carrier and axle tube assembly. The housing inside that holds the differential gears is called the "differential case'. The differential case is available with limited slip [positraction] or conventional [open] components.
