Author Topic: Muncie vin #'s  (Read 24707 times)
VI009DZ
Re: Muncie vin #'s
« Reply #15 on: March 26, 2007, 07:24:09 PM »
It wou
I think the stamping on LA Muncies depended on the mood of the plant worker.
It would be comical to find one stamped about 100 times all over the place by a pissed off, stressed out worker!!!!
Re: Muncie vin #'s
« Reply #16 on: March 27, 2007, 04:49:46 AM »
Usually stamped at least three to four times.  On the very front part of the case, at the rear of the case, on the center bearing support, and the tailshaft lip.
Jerry
Now that's something I didn't know and will have to check!  Is it always at least three to four times?
I got under the old Z tonight to check for multiple vin stampings on the Muncie and could only find two.  Both stampings are on top of the case, right (passenger) side, one in the front and one in the back as Jerry described.  There could be more, but with the transmission in the car and 39 years of grime, that's all I could find with my mirror.  There is also a metal tag attached to transmission side cover with the number 3915085 embossed on it.  What does this number reference?
Re: Muncie vin #'s
« Reply #17 on: March 27, 2007, 02:07:04 PM »
[/quote]
That tag is the "assembly number" for the transmission - it identifies the specific combination of main, side cover, and tailhousing castings, gearset type and ratios, input and output shafts, and output shaft speedo drive gear diameter and tooth count to suit a specific usage. Although most Muncies look the same externally, there were about a dozen different "assemblies" used, and that part number tag (and the broadcast code) identified which one they were.
Re: Muncie vin #'s
« Reply #18 on: March 27, 2007, 04:50:38 PM »
Where can I found the specific usage of this number (3915085)?  I'm curious if this number was only used for a Z/28?
Re: Muncie vin #'s
« Reply #19 on: March 27, 2007, 05:18:45 PM »
Paul the 3915085 M21 Muncie 4 speed transmission had multiple usage in 68 (see the scan below).
Re: Muncie vin #'s
« Reply #20 on: March 27, 2007, 11:55:50 PM »
Thanks Ed!  Where did you find this info?  Your P&A manual?  Also, what does "C.A.C." stand for?   ???
Re: Muncie vin #'s
« Reply #21 on: March 28, 2007, 12:21:37 AM »
Yup. The P&A.
C.A.C. stands for "Cold Air Conditioning" (as opposed to "Hot" Air Conditioning I guess!!)
Re: Muncie vin #'s
« Reply #22 on: March 28, 2007, 06:18:52 AM »
Close. :)
"Car Air Conditioning"
Re: Muncie vin #'s
« Reply #23 on: March 28, 2007, 01:57:21 PM »
OOPS! You're right Kurt. I should have looked in the abbreviations section of the P&A before I spoke!!
Re: Muncie vin #'s
« Reply #24 on: March 28, 2007, 06:09:12 PM »
Thanks guys.  C.A.C., that's a new one for me.   ::)
Ron C.
Re: Muncie vin #'s
« Reply #25 on: March 28, 2007, 06:21:33 PM »
Never seen a transmission stamped more than once (except for maybe an overstrike).
my 71 ss chevelle m22 was stamped twice.once on the flange (side) and on the case next to the flange.
fireZ
Re: Muncie vin #'s
« Reply #26 on: April 28, 2007, 01:19:49 PM »
My 68 LOS z28 is stamped also in 2 spots.Each has a B behind the numbers and it is a 03e car with 302  tags
1968 Z28 LA Built
LIC # RPO Z28
