Author Topic: Original Tri Power  (Read 3515 times)
VINCE Z28
Original Tri Power
« on: February 25, 2020, 02:28:42 AM »
Hey guy is this a original 1969 tri power air cleaner? And will a 4055-1 center carb. (Date is 103) hurt the value of a tri power?
« Last Edit: February 25, 2020, 02:54:59 AM by VINCE Z28 »
VINCE Z28
Re: Original Tri Power
« Reply #1 on: February 27, 2020, 06:00:42 AM »
Do any of you guys know if this air cleaner is original?
Kelley W King
« Reply #2 on: February 27, 2020, 01:55:13 PM »
You have two parts. The base and the cover. The cover should have the silkscreen or signs of it. The original covers are also heavier. The hose on the base is not correct. There should be an elbow with with a screen inside the base. New lids are fairly cheap. Ebay usually has several which can give you  some idea of value.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
VINCE Z28
« Reply #3 on: February 27, 2020, 03:58:58 PM »
Thanks Kelly. She is asking 2900. for cleaner, carbs and intake. The center carb is 4055-1 front and back is 3659.Vince
« Reply #4 on: February 29, 2020, 12:27:44 AM »
Agree with Kelly!
