Author Topic: 68 Engine Block Missing Casting Date?  (Read 3074 times)
69RALLYSPORTZ28
« on: February 20, 2020, 01:23:46 AM »
Has anyone ever seen an engine block or heard of an foundry explanation as to why a 68 or early 69 engine block ( 327/302/350) would be missing the the casting date, unless the casting date was intentionally ground away during a rebuild?
Re: 68 Engine Block Missing Casting Date?
« Reply #1 on: February 20, 2020, 04:14:39 AM »
You are looking on the lower rh side of the center of water jacket? Correct? Probably will need a pic to clarify and see what you are seeing.
« Reply #2 on: February 20, 2020, 04:23:08 AM »
IIRC the foundry used 'letters' for 'foundry test' casting (to test new castings).  In some cases, those castings have been used.  I have seen one with an 'M' in the place of the casting date.
You should be able to find a thread addressing this issue which was discussed in the past.
