Author Topic: 67 l78 fuelline pump to carb  (Read 7198 times)
john302
« on: February 16, 2020, 09:29:27 PM »
Is anyone making the correct fuelline from pump to carb for a 67L78. Its a very unique . 67 only. Called the Right Stuff and they made a few correct ones ,but didn't keep the pattern. thanks
luv2sixty9
Re: 67 l78 fuelline pump to carb
« Reply #1 on: February 19, 2020, 04:12:05 PM »
Kerry has the most correct fuel line that he had Right Stuff make for him. I believe that he still have a couple left.
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
« Reply #2 on: February 19, 2020, 04:37:52 PM »
I assume you are referring to the non smog fuel line?  Idk if anyone makes it correctly.
« Reply #3 on: February 19, 2020, 04:56:42 PM »
anyone got comparative photos ?
just for reference
interesting topic.
« Reply #4 on: February 19, 2020, 05:55:14 PM »
I was just informed that the one made by Right Stuff or In-line cant remember was used from a certain 4K car.  There might be a way to have it copied.  I will check and see if anyone is willing to help out.
« Reply #5 on: February 20, 2020, 12:27:53 PM »
And here is a photo of said fuel line.
« Reply #6 on: February 20, 2020, 05:31:50 PM »
Related question:
1967 May 4K Coupe build in LOS but Shipper report is Wyoming sales
SMOG or NO SMOG?
JIM
« Reply #7 on: February 20, 2020, 10:43:52 PM »
Hard to say for certain without seeing the car but I would bet on it being a smog car being that late into production.
« Reply #8 on: February 21, 2020, 06:12:11 AM »
Fair assumption that any non-California destination car didn't have the optional smog.
MO
« Reply #9 on: February 23, 2020, 03:24:52 AM »
Most likely no smog.
L78racer
« Reply #10 on: February 23, 2020, 10:25:06 PM »
i believe this is a pic of a '67 fuel line.
john302
« Reply #11 on: February 24, 2020, 02:27:04 PM »
I called the Right Stuff and they found the correct part number. Will be here today so will see if its correct?Thanks for all the help .
plumL78
« Reply #12 on: February 28, 2020, 09:07:41 PM »
the correct part # is FPC67WK A  but last I heard they lost their pattern and couldn't make them any more. They still cant make it 100%. The bend coming out of the fuel pump is not correct  the machines today cant make it. They made a couple for me last year. Most people will never know the difference
jeffschevelle
« Reply #13 on: April 12, 2020, 08:39:02 PM »
Keri made the pattern off my unrestored 67 L78 Chevelle.
The right stuff p/n is FPC67WF A  (not FPC67WK A).  And you have to tell them to put the space in before the A or they cannot find it in their computer!!
It is not "perfect" at the bottom bend but is MUCH better than the 68 version which they were selling as 67-68 before.
Good luck!  Jeff Helms
