Author Topic: 67 396 Oil pan details  (Read 4928 times)
john302
« on: February 16, 2020, 09:25:46 PM »
Looking to find the details on a 67 396 oil pan. Thinking they are alittle  different then a 68 or 69. Any help would e greatly appreciated . thanks
jeffschevelle
Re: 67 396 Oil pan details
« Reply #1 on: April 12, 2020, 09:24:09 PM »
There were at least 4 different Chevelle/Camaro big block pans used in 67.  Only the 3rd and 4th versions would have been used on 67 Camaro 396's (or maybe only the 4th, depending on when that version began use).
1st style has less indentions on the sides (more than a 66 Chevelle pan but less than the other versions listed below and shown in the pics), and has the front center bolt hole.  I have a late October 66 car with that pan.  I don't have access to one of these pans off the car so don't know what the baffle looks like.
Pics of the 2nd style are below.  2nd style has front center bolt hole.  The baffle has an X pattern stamped in it, rather than the V pattern in 69+ pans.  Not sure when that version started, but it had to be before Dec. 20, 1966.
3rd style is the same as 2nd style except without front center bolt hole.  Per GM documentation that bolt was dropped beginning Dec. 21, 1966.
4th style is the same as 3rd, except the drain hole is moved forward to be in the deepest part of the sump.  This is also identical to a 68 pan.  Not sure when that changed happened, but I have an unrestored car with T0509EG engine that has that pan, which is the earliest verified original I have seen.
Happy hunting!
jeffschevelle
« Reply #2 on: April 12, 2020, 09:26:17 PM »
Baffle comparisons
jeffschevelle
« Reply #3 on: April 12, 2020, 09:26:56 PM »
Not sure why those last two are squished out of shape, but at least you can see the indentions I am talking about.
« Reply #4 on: April 12, 2020, 11:36:25 PM »
Jeff,
  This is great info!
Question....when the oil drain plug was moved forward, would that place the hole between the two vertical impressions?  I checked my two 67 L35's and this is what I see:
1967 Engine assembly date:
   T0214MZ - Third design pan - no center hole and the oil drain is like your 1st picture whereas the hole is slightly under the larger stamped impression. Two impressions in the bottom of the pan.
   T0308MW - Fourth (?) design - no center hole and the oil drain hole is centered between the two stamped vertical impressions. This does place it in the deeper part of the sump. Two impressions in the bottom of the pan.
jeffschevelle
« Reply #5 on: April 13, 2020, 03:37:48 AM »
Correct, the 4th design has the drain hole a little forward of centered on the hump between the two indentions.  So if that pan is original to that engine, that's a new earliest date for the 4th pan!  Thanks -
« Reply #6 on: April 13, 2020, 05:34:19 AM »
Thanks Jeff!
« Reply #7 on: April 13, 2020, 12:42:09 PM »
Hi Jeff,
  Yes, that pan is original to the motor.
I've had this car for 40+ years and when I think I know all there is about it, something new comes up.
Thanks!
