Author Topic: When would the SPL spring washer not be used?  (Read 9665 times)
« on: February 12, 2020, 01:28:35 PM »
  I was taking inventory for what hardware might have to be replaced if I decided to restore the original 67 LOS coupe, and while reading the 67 AIM something puzzled me. In the attached picture I see mention 'Spring washer (when used'). I checked my original 04B LOS and restpred 05B NOR and the washers exist on all 4 mount points and have the indented bolts. The question is, when would those spring washers not be used?
Petes L48
Re: When would the SPL spring washer not be used?
« Reply #1 on: February 12, 2020, 04:19:13 PM »
To clarify, you have that special spring washer in addition to the larger regular flat one #11?  I think my 11B LOS L48 just had the larger flat washers.
« Reply #2 on: February 12, 2020, 04:30:27 PM »
Hi Pete,
  Correct, I see the larger washer and the smaller 'spring' washer under the bolt heads.
What year is your car?
« Reply #3 on: February 12, 2020, 04:51:35 PM »
The special spring washer (P/N 3914049) was only used on the #2 and #3 body mounts. The drawing showing the mounts is "typical", meaning it represents the way the mounts need to be installed.
« Reply #4 on: February 12, 2020, 06:01:50 PM »
What's confusing, Ed, is there are no other bushing assemblies like the ones for #2 & #3 on the car to make that note in the AIM.
« Reply #5 on: February 12, 2020, 06:04:14 PM »
I'm not sure what you mean Mike. There's also body mount number 1, which doesn't use the special washer.
Petes L48
« Reply #6 on: February 12, 2020, 06:15:52 PM »
Hi Pete,
67.  I'm going off memory and could be mistaken.  It's in restoration, so I can't go take a look, plus it's disassembled at this point.
« Reply #7 on: February 12, 2020, 06:19:44 PM »
 I thought that too Ed, but the radiator mounting doesn't look like the body mount in that a separate nut is used instead, and the bolt approach direction is opposite.
Petes L48
« Reply #8 on: February 12, 2020, 06:20:35 PM »
Looks like the repro kits include that spring washer for the #2 and #3 points.  Here's the one HBC sells
https://www.heartbeatcitycamaro.com/store/product/19631/67-68-Camaro-Firebird-Nova-Subframe-%26-Core-Support-Body-Bolt-Kit-Correct/
« Reply #9 on: February 12, 2020, 06:40:20 PM »
Hi Pete,
Guess it’s possible Pete but believe the norm would be bolt and two washers on 2 & 3 as Ed was alluding to.
« Reply #10 on: February 12, 2020, 06:50:14 PM »
Note that you can't always take the AIM as gospel. Some of the notes and illustrations are for "reference" purposes only and may not reflect the "exact" way things were done.
« Reply #11 on: February 12, 2020, 07:12:50 PM »
The last gospel I used to listen to was from the Reverend Billy Sol Hargis  :)
You may remember him, Ed  :)
Thanks!
LVN 67
  • John 67 NOR 02E L-35/T400, 6th Owner
« Reply #12 on: February 12, 2020, 10:38:33 PM »
Good afternoon
 I too am in the process of getting ready to replace my sub frame bushings. I have a question about the 67 mounting bolts in spots 2 & 3. I was able to get the bolts out and they don't look like the ones you see in replacement kits. They look like the bolts for the radiator support, only larger. Could they be the bolts that were noted in the revisions sect of the AIM, part # 3901305? I'll try to get some pictures.
Thanks, John
LVN 67
« Reply #13 on: February 12, 2020, 10:40:17 PM »
Sorry about the upside down pictures :-[
« Reply #14 on: February 12, 2020, 11:19:22 PM »
Those are the same style that came on my 67 04B LOS & 05B Nor
