Author Topic: Front wiring harness routing  (Read 9655 times)
« on: March 22, 2007, 11:06:01 PM »
I didn't get a definative answer so I will try again.  Does anyone know where and or why some 68 non RS Z28's had the front wiring harness routed between the inner and outer fender and some seem to have it connected to the inner fender with two vertical straps?  Is it based on options or what, and does the washer hose go with the harness wherever it goes?  I have a very light optioned Z: AM radio, console guages, no power steering.  When I bought it, the washer hose was routed to the inner fender with two vertical straps attached to it.
deejaygee
Re: Front wiring harness routing
« Reply #1 on: March 23, 2007, 04:57:23 PM »
Dude, get the factory assembly manual. All this stuff is covered in great detail there.
« Reply #2 on: March 23, 2007, 09:10:35 PM »
I have it and it shows it being routed between inner and outer fenders.  However, I have seen some original cars that have it attached on the fenderwell as mine was.  I'd like to know from someone that knows for sure when and why this is.
Pex68
« Reply #3 on: July 01, 2009, 03:01:49 AM »
Hey I see this is an old post but just wanted to add my 2C because I just ran into this.  My car is a 68 12D LOS.  Original harness was routed outside fender with washer hose retained by the 2 straps.  Got hit at Nationals last year for it not being inside fender so I moved it for this year.  There was a 68 04C LOS Z in survivor this year...had the harness routed outside fender with washer hose.  Noted it to Judges but they said the car had some hardware issues and they never seen it run outside the fender.  If you’re going concours I guess it needs to be inside the fender.
Chris P
« Reply #4 on: July 01, 2009, 06:45:11 AM »
You're not the only one I've heard that from.  I guess you have to do what you have to do.  I think I had this topic on TC and there were some pics of cars with the wires and hoses on the fenders like ours and they were factory pics.
Pex68
« Reply #6 on: July 02, 2009, 11:54:02 AM »
Thanks for that, great info!
Chris P
fireZ
« Reply #7 on: July 02, 2009, 12:10:10 PM »
My 02E Z28 from LOS had the wiring in between the inner and outer fenders.
1968 Z28 LA Built
LIC # RPO Z28
1968 Z28
« Reply #8 on: July 02, 2009, 06:23:02 PM »
My '68, 07c, NOR Z28 has the light harness and washer hose routed between the inner and outer fender.
Jerry G.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
