Author Topic: HOOD HINGES SPRING  (Read 11756 times)
ALLZS
HOOD HINGES SPRING
« on: February 03, 2020, 09:16:31 PM »
the large spring on the hood hinge is it plated or painted  this is on a 69 Camaro thanks
Petes L48
Re: HOOD HINGES SPRING
« Reply #1 on: February 03, 2020, 09:55:27 PM »
Phosphate.  A couple old threads below.  You can find more using the Search tool/button on this forum:
http://www.camaros.org/forum/index.php?topic=11328.msg90792#msg90792
http://www.camaros.org/forum/index.php?topic=8129.msg55277#msg55277
ALLZS
« Reply #2 on: February 04, 2020, 01:19:46 PM »
where they black or gray phosphate or did they come both ways
« Reply #3 on: February 04, 2020, 03:09:54 PM »
dark gray.
« Reply #4 on: February 04, 2020, 05:14:57 PM »
If you want to know exactly what they look like without the screen color inaccuracy, buy a brand new GM pair. I just got two more with the umpteenth pair of hinges I just had rebuilt.
« Reply #5 on: February 04, 2020, 06:56:34 PM »
« Reply #6 on: February 05, 2020, 01:27:54 AM »
The original spring is not phosphate’d imo. The spring is natural spring steel which has a naturally dark looking finish.
« Reply #7 on: February 05, 2020, 01:55:49 PM »
I concur.
Edgemontvillage
« Reply #8 on: February 05, 2020, 02:21:25 PM »
A photo of my recently restored hood hinge and spring. The hinge was zinc phosphated and the spring was cleaned and oiled.
« Reply #9 on: February 05, 2020, 02:23:16 PM »
Damn that looks good Lloyd!
« Reply #10 on: February 05, 2020, 09:58:17 PM »
Ditto!
Edgemontvillage
« Reply #11 on: February 06, 2020, 08:07:40 PM »
Thanks guys!
Petes L48
« Reply #12 on: February 06, 2020, 09:06:09 PM »
So is the consensus that the hinge is zinc, not manganese phosphate, and the spring is neither?
I plan on doing my hinges is a few weeks and have a NOS set of springs in the package that just need cleaned up.  Maybe just Evaporust and oil the springs?
« Reply #13 on: February 06, 2020, 10:24:02 PM »
Yes,evaoprust and some oil type protection on the springs. Hinges are the lighter phosphate as Lloyd pointed out. His are 100% correct and what the goal look should be.
ALLZS
« Reply #14 on: February 07, 2020, 12:08:53 AM »
this site is  fantastic thanks for every ones input
