Author Topic: Location of Headlight Relay board for 1967 RS/SS  (Read 2965 times)
Tinbasher
« on: February 02, 2020, 06:01:02 PM »
I'm look for the measurements for the location of the Headlight Relay board for a 1967 RS/SS. We replaced the front fenders with OEM fenders but the hole or holes aren't there on the Lt. Frt. Fender. On the originial there is only one hole but to me it looks like it's too far forward to mount the board and connect the wires running to the rear of the boards. Pictures or a Drawing would be a big help. Of course the fender is painted now that we found this!! JP
Re: Location of Headlight Relay board for 1967 RS/SS
« Reply #1 on: February 02, 2020, 06:29:18 PM »
See attached for the hole locations. I put a separate image for view A to show the details better.
 Let me know if you need pictures from the car.
Good luck!
« Reply #2 on: February 02, 2020, 06:31:00 PM »
This is a friends 67 L78 in Deep storage since 1983 stuck in time. Repainted 1985 put 3 miles on it then LIFE happened.
67 RSSS 396/375
Blown up RS hardware
Other here will likely give you exact dimensions, wonder if the Assy manual details drilled location or was it a salient characteristic of the PN driver RS fender?
Tinbasher
« Reply #3 on: February 09, 2020, 03:17:13 PM »
Thanks Guys. This helped alot. Fun your friends car is the same colour as the one where working on.
« Reply #4 on: February 10, 2020, 04:41:51 PM »
(*all in Fun)
Are you Sure,????
Can you see the purple pearl (1983 DDL PPG Laq) he kicked up the stock BY a bit
Hope to post more about his car when he gets back into the hobby otherwise it (1967 4K) lays hidden
