Author Topic: LA/Nor Vehicle ID numbers  (Read 8779 times)
Adz28
« on: March 21, 2007, 08:49:31 PM »
Since the vehicle ID numbers were assigned in sequence at the plant, could a car produced in LA have the same last 6 digits as a car produced in Norwood? For example, could there be 124379L520247 and 124379N520247 VINs? Or are they unique?
Mr12771
Re: LA/Nor Vehicle ID numbers
« Reply #1 on: March 21, 2007, 08:55:57 PM »
I don't know the answer but wouldn't that be neat for a collector.
« Reply #2 on: March 21, 2007, 09:30:52 PM »
Both factories used the same numbers. There's a Los Angeles 8L300001 and a Norwood 8N300001 VIN 68 Camaro out there somewhere!
« Last Edit: March 21, 2007, 10:17:49 PM by bertfam »
Mark
« Reply #3 on: March 21, 2007, 09:31:24 PM »
In 69 the last 6 digits of the VINs could be the same at both the LA and Norwood plants, ie N523456, and L523456.  The 69 body numbers were unique since they were assigned by the central office.  In 67 and 68 both the VINs and the body numbers could be repeated, ie N100001  NOR100001, and L100001 LOS100001 (of course these numbers don't really exist) since the VINs were sequential, and the body numbers were assigned by each plant.
Actually there was a Norwood N300001, and a Los Angeles L300001.  The first production VIN is always number 1.
« Last Edit: March 21, 2007, 09:33:28 PM by Mark »
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #4 on: March 22, 2007, 05:37:06 AM »
And we have several instances of 'repeated' body #'s and VIN's from different plants in the database.
Adz28
« Reply #5 on: March 22, 2007, 05:09:09 PM »
Thanks for the info... Another piece of Camaro trivia to make me popular at parties ;D
ggtsvnv
« Reply #6 on: March 23, 2007, 03:59:31 AM »
 Is it possiable that a Camaro might have VIN N300001 and a Firebird L300001? Being both cars were built at the same plant? Or did Pontiac have a different number sequence?
« Reply #7 on: March 23, 2007, 02:21:53 PM »
No. For the 67-69 Firechicken, sequential production numbers started with 600001 for 6-cylinder models and 100001 for V8 models. Although the 1967 Camaro also started with 100001, the 67 Bird was only built in Lordstown, Ohio ("U" designation), so although the numbering sequence would match (1xxxxx), the plant designator woudn't.
Van Nuys didn't start building Firechickens until 1968 (Norwood until 1969), and at that point the numbering sequence for the Camaro went to 3xxxxx (1968) and 5xxxxx (1969), while the Bird stayed with the 100000 (V8) and 600000 (L6) sequence.
« Last Edit: March 23, 2007, 04:20:00 PM by bertfam »
« Reply #8 on: March 23, 2007, 03:25:16 PM »
Firebird production was transferred from Lordstown to Norwood on April 15, 1969; I removed the tooling from Lordstown and had it shipped to Norwood as part of preparing Lordstown for the buildout of the "F" and "B"-body and conversion of the plant to Vega production.
« Last Edit: March 23, 2007, 03:27:22 PM by JohnZ »
