Author Topic: Strange vin number on engine to date numbers .  (Read 7369 times)
Mr12771
« on: March 21, 2007, 08:18:14 PM »
I just bought this motor and something just doesn't seem right to me. The casting date is I 29 6 the front stamping is V1011MT but the vin stamping is 7N183876. From what I found online that vin should be around Feb 1967. Four months apart, could that be right? I can take a picture and send it if you would like.
Re: Strange vin number on engine to date numbers .
« Reply #1 on: March 21, 2007, 10:20:06 PM »
Mike,
Although it's outside the "normal" range, it's still within the "accepted" range so it's possible. Can you take a picture and post it? We'd like to have a look.
Mr12771
« Reply #2 on: March 22, 2007, 02:19:00 PM »
Here is the picture. I hope it works. Also is this vin in the database?
dab67
  • 67 SS
« Reply #3 on: March 22, 2007, 03:01:36 PM »
Ed;
Was it acceptable to use the letter "I" for the number one (1)?
dab67
« Reply #4 on: March 22, 2007, 03:31:42 PM »
Ed;
dab67
Yes - the "I" character was used much more often than the "1" character in the engine plant stamp.
jmcbeth
  • 1st and 5th Gen Camaros
« Reply #5 on: March 23, 2007, 01:11:19 AM »
I had a very similar question regarding a block I purchased. See the post on this forum entitled "Do these 302 DZ Block Numbers make Sense?". After some discussion, it was determined that the block is "the real deal", although I never figured out why there was a 4 month difference between the casting date and the assembly date. It would probably help to post a picture of the casting number and casting date for the experts  to help.
Best of luck,
JmcBeth
John
1969 Camaro Z/28 RS
Numbers Matching
