Author Topic: 1969 Z/28 7801149 SMOG PUMP  (Read 3422 times)
1MeanBull
« on: January 18, 2020, 08:28:16 PM »
hi, can anybody tell me if they ever installed "Y" 7801149 smog pumps on the 1969 Camaro Z/28. and as far as a May assembled block. what do I have as far as time prier to assembly for a smog pump in 1969?
Re: 1969 Z/28 7801149 SMOG PUMP
« Reply #1 on: January 18, 2020, 08:43:15 PM »
rszmjt
« Reply #2 on: January 18, 2020, 08:46:05 PM »
What is a “Y” 7801149 ?
All 69 Z28,s did use the 7801149 pump , with white fan, as far as dating anywhere from 2 weeks to 4 , I’m sure you could go even more with no controversy.
« Reply #3 on: January 18, 2020, 09:56:38 PM »
Y suffix denotes the pressure relief valve in the pump body.
rszmjt
« Reply #4 on: January 18, 2020, 10:22:18 PM »
Then OP has a 68 pump, not correct for 69
1MeanBull
« Reply #5 on: January 18, 2020, 11:35:02 PM »
hi, thanks for getting back to me, yes I understand that the letter "Y" stood for pressure relief valve installed. all the smog pumps I have seen for 1969 Z/28 end in the letter "S". even in Jerry MacNiesh book the pump illustrated end in the date code with the letter "S" for Saginaw plant. so like I ask does anybody know if they know or seen a smog pump for 1969 Z/28 with a date code ending in the letter "Y"
1MeanBull
« Reply #6 on: January 18, 2020, 11:39:11 PM »
thanks again, the site was very helpful. and for anyone else 1969 Z/28 7801149 smog pumps only end in a "S"
