Author Topic: Was the oil filter mounted when the motor was sprayed at factory?  (Read 9272 times)
 For 1967 motors using the separate oil filter & housing, was the filter on the motor when it was sprayed at the factory?
I figured by the time it was sprayed, it had gone through its bench test, hence the need for oil.
This question probably relates to 68-69 spin-on filters too.
Re: Was the oil filter mounted when the motor was sprayed at factory?
« Reply #1 on: January 07, 2020, 04:40:52 AM »
Sprayed, I assume you mean painted? I have only seen the canisters black painted. Not orange.
« Reply #2 on: January 07, 2020, 04:49:27 AM »
Hi Bentley,
   Was I was getting at is if over-spray was possible on the oil filter housing during engine painting process. If it were mounted then I am guessing the filter housing may have had a cover over it so the filters silk screen wasn't painted over. Sort of like with the coffee can on the distributor during painting.
« Reply #3 on: January 07, 2020, 02:29:58 PM »
Quote
No it wasn't. It was attached at Norwood or LA. From the ASSEMBLY ARTICLE by John:
Quote
From here on, all the detail dress items were added (plug wires, coil, engine harness, battery cables, carburetor, pulleys, alternator, starter, fan and clutch, A/C compressor, power steering pump, transmission cooler lines and fill tube, A.I.R. pump, diverter valve and air manifolds, drive belts, dipstick and tube, oil filter, engine and transmission mounts, PCV plumbing,
« Reply #4 on: January 07, 2020, 03:38:25 PM »
 Thanks, Ed. I've read that and found it confusing in that when an assembled motor was tested, I assume it had oil its sump. Was the oil drained after testing and the motor shipped with a dry sump? If shipped dry then I wonder how debris was kept from the now wet oil filter adapter unless there was a cover placed over it. If the oil was drained after each engine test, I wonder if the oil was filtered and reused for the next motor test otherwise it would be hard to fathom such a huge waste of oil.
« Reply #5 on: January 07, 2020, 04:29:04 PM »
Yes, I remember us discussing this a while back and John said when the engine was built in Flint (or Tonawanda), it was filled with oil, tested, then the oil drained. I don't remember what he said about re-using it on the next engine, but I'll find out.
Stay tuned...
« Reply #6 on: January 07, 2020, 05:18:41 PM »
Ok, got in touch with John and he said that the drained engine plant "first-start" oil was filtered and re-used, and there was no oil filter can or cartridge to deal with. An adapter fixture was used at hot test, and the oil filter was installed at the car assembly plant.
Thanks John!
Petes L48
« Reply #7 on: January 07, 2020, 05:47:16 PM »
So this test process at the engine plant was also where the cam was run-in?
« Reply #8 on: January 07, 2020, 07:14:31 PM »
No, not really. I'm paraphrasing and adding my own comments, but here's the poop:
According to John, there wasn't any attempt to "break-in" the cam at the engine plant since it only ran 30 seconds to a minute on the hot test fixture before being drained and shipped. In addition, there wasn't any attempt to "break-in" the cam at the final car assembly plant either. Each car only ran for a couple of minutes at idle after car-start on the Final Line, spent a minute or two on the roll test, and never ran again except for rail and/or haulaway truck loading and unloading. Let's face it, at 5000 engines a day, there just wasn't enough time to break them in, and it wasn't needed anyway.
The reason they didn't need to have a break-in period was because production (and service) camshaft lobes were Parkerized for improved initial surface oil retention. Hot-rod aftermarket cams without Parkerized lobes are VERY sensitive to initial break-in so they have to be run at approx 2500 RPM for around 20 minutes or so. Production cams depend on lobe Parkerizing (increasing the resistance to wear through the application of a chemical phosphate conversion coating) to avoid being "wiped".
« Reply #9 on: January 07, 2020, 07:35:16 PM »
 Thank you Ed and John for the clarification!
Petes L48
« Reply #10 on: January 08, 2020, 02:21:40 AM »
Yes, thanks for the all the info Ed.
adjudimo
« Reply #11 on: January 08, 2020, 03:48:18 AM »
Nice job Ed. You guys (John, etc.) never fell to share your knowledge and make it easier to understand the procedures taken to do much of the things most of us would never know. Much appreciated!
« Reply #12 on: January 08, 2020, 02:28:42 PM »
You kidding? I learned something new too!!! John is such an encyclopedia when it comes to the assembly procedures that every time I talk with him I learn something new!
adjudimo
« Reply #13 on: January 08, 2020, 03:45:01 PM »
It would be so nice if a few of the folks. such as John and others in the know, could get together and have an informal discussion video taped for the sake of prosperity. The wealth of knowledge that could be captured would be absolutely tremendous for sure.
« Reply #14 on: January 08, 2020, 05:37:07 PM »
Just search up his posts or read his articles. There's lots there already documented.
