My friend actually researched the tubular arm upgrade. If you go that route do your homework, on the camber caster improvements, because my friend explored the LBS, and weight wise some tubular arms weigh MORE that the stock stamped ones. They all look pretty, but make sure you're getting what you want out of the arm.
