Author Topic: 1969 Hood Striker Assembly Finishes  (Read 22617 times)
67conv6cyl
Re: 1969 Hood Striker Assembly Finishes
« Reply #30 on: December 11, 2019, 02:26:20 PM »
Also the lower inner section of the tail panel where the frame rails meet the tail panel is galvanized...at least is is on my 67 convertible.
HOGDADDY
« Reply #31 on: December 11, 2019, 02:59:34 PM »
Yes mine is also. I forgot about that.
« Reply #32 on: December 11, 2019, 07:52:55 PM »
None of the 4 bolt prints are available, so no info that way. :(
« Reply #33 on: December 13, 2019, 03:44:34 AM »
Pic of my Z11's striker. Looks like the other examples - light phosphate on the plate, maybe zinc on the bolt, definitely dark phosphate on the cup. I've probably got some NOS pieces ratholed, try and find them this weekend.
JonQ
« Reply #34 on: December 23, 2019, 04:42:24 PM »
Hey all, here are 2 pictures of before and 2 after i dipped it into EvapoRust for a couple of hours. My 69 Z RS is a VN built and production date of 12/19/68
Jon
JonQ
« Reply #35 on: December 23, 2019, 05:05:17 PM »
Last picture still shows the bubbling of the WD40 I sprayed
rszmjt
« Reply #36 on: December 23, 2019, 08:56:51 PM »
06A Z28 , cleaned in evaporust and re oiled to avoid rusting, spring was repainted, but phosphate is original, owned the car since 74.
Edgemontvillage
« Reply #37 on: January 06, 2020, 04:19:35 PM »
Many thanks for all the submissions. I dare not rule out exceptions however I've concluded the assembly, including the bolt (adjuster shaft), was very likely zinc phosphated originally and any appearance of a natural or galvanized finish on the bolt is due to burnishing or wear over time. Its generally accepted that gloss black is correct for the spring. Here is how I restored the assembly for my project:
HawkX66
« Reply #38 on: January 06, 2020, 04:59:27 PM »
Looks great Lloyd. I think your conclusion is right on the money.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
« Reply #39 on: February 12, 2020, 01:01:42 PM »
Lioyd, was reviewing what I found on our 68 and reason for doing ours in phosphate. Post 256 dated 3/16/11
https://www.camaros.net/forums/133-build-projects/182584-time-another-68-z-28-restored-18.html
x66 714
« Reply #40 on: February 12, 2020, 01:53:13 PM »
How do you use that site with all the ads & pop ups? I stopped going there because of that fact....Joe
Edgemontvillage
« Reply #41 on: February 12, 2020, 05:22:09 PM »
Joe, off topic, however if you want to turn off pop-ups for the Windows version of the Google Chrome web browser here's how. There is a lot of good information on TC.
Chrome (Windows)
Click the Customize and control Google Chrome menu (the three dots in the upper right corner of the window below the close window X)
Select Settings.
Click Advanced at the bottom of the page
Under Privacy and security, click the Site Settings button.
Select the Pop-ups and redirects arrow.
Click the Blocked (recommended) slider.
You're done.
To disable the pop-up blocker uncheck the Blocked (recommended) box.
x66 714
« Reply #42 on: February 12, 2020, 05:32:29 PM »
Thank you Lloyd...Joe
« Reply #43 on: May 06, 2021, 01:27:09 AM »
While restoring some items that I planned in selling, I referenced this thread and hopefully came close to the intended result.
uscrichter
« Reply #44 on: May 07, 2021, 07:06:20 PM »
I am working on restoring these parts for my car the day and notice that after a thorough cleaning that the Striker pin has a finish that is almost identical to the phosphate coating on the clutch bell crank! much lighter in appearance than other items but definitely a light phosphate.
