Author Topic: 1969 RSSS L78 Project  (Read 14594 times)
Re: 1969 RSSS L78 Project
« Reply #15 on: December 04, 2019, 02:46:17 PM »
"Chirping 2nd gear." That's cute. ;-) If you aren't smoldering third you need a new power plant lol. Even with 3.31s I couldn't think about going full bore in 2nd. Just busting your chops Gary...
No problem Dave... :)    As I said, it's a factory original stock '72 BASE 350 that I rebuilt (30 over) about 15 yrs ago..  For what it is, I'm pleased with how it runs... :)    (factory rating was 200 bhp).. :)
PS.  What you really need is to get some of that Big Fat Block weight over the drive wheels!!  :)
HawkX66
« Reply #16 on: December 04, 2019, 04:37:34 PM »
You are absolutely right!
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
Driveway_finds
« Reply #17 on: December 05, 2019, 06:58:48 AM »
Kurt-
Car has a BU 12 bolt in it. Thank you guys for all the replies! Excited to see it on the road soon!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
Check out driveway_finds on Instagram!
« Reply #18 on: December 05, 2019, 08:35:38 PM »
Thanks! Don't see too many of those in that drivetrain. What's the stamped axle date?
Driveway_finds
« Reply #19 on: December 11, 2019, 04:09:45 AM »
It’s got a BU 10 10 G1 E code
-Dustin
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
« Reply #20 on: December 11, 2019, 06:35:34 AM »
Thanks! Not original to the car, btw.
« Reply #21 on: December 11, 2019, 03:51:15 PM »
Probably had a 3.55 axle originally.
Driveway_finds
« Reply #22 on: December 12, 2019, 08:03:36 AM »
Curious what a 69 3:73 rear axle code would be? I assumed ours did not have the original rear
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
« Reply #23 on: December 12, 2019, 01:19:46 PM »
The BU code was originally the std rear in '69 Z28s, and would have been 3.73:1 ratio.
« Reply #24 on: December 12, 2019, 02:17:58 PM »
Gary, positraction was recommended for Z28s - but not required. 3.73 was the standard ratio. Yes BU is the most common, but there are Z28s that received the BO 3.73 open rear end.
« Reply #25 on: December 12, 2019, 02:45:27 PM »
You are right Bryon,, but your answer wasn't complete either (to his question of 'Curious what a 69 3:73 rear axle code would be?')
The complete answer would have included the QX code as well as the BU and BO codes, but the BEST answer of all would have been to refer him to the full table in the archive...      http://www.camaros.org/drivetrain.shtml#AxleCodes
« Reply #26 on: December 13, 2019, 01:07:41 AM »
I don’t think we fully understand the question.
In 1969 a 3.73 ratio was standard for a Z28 and the optional - performance - ratio - for L78 and L89. I think a 3.73 ratio could also be special ordered with L34, L48 and LM1.
« Last Edit: December 13, 2019, 02:34:19 AM by bcmiller »
