Additional pictures showing the lower floors being cleaned up and stripped of black spray paint that the previous owner added. The car is progressing along nicely now.
Broken lower leaf found - drivers side.
Lloyd Costley comes up big with a gratuitist spare provided from one of his original sets!
Trunk floor and rear panel view after some cleaning
Lot's of gray primer was to be found around this car.
Inner returns cleaned up nicely. Trying not to overdo things here.
Original fisher body stamping on the lower return - drivers side
Everything in the rear axle tunnel is now cleaned up and done
Found a T41 date stamping in the floor. I never knew about these until another member educated me on the subject. :-)
Skipping ahead to the inner fenders which have now received some cleaning to remove paint.
I still have a couple of weeks of cleaning to get through with most of the front end and lower suspension to be done. Once I'm through the engine bay, the diff and the driveline will be going back in. That's when I'll drop the front suspension and start detailing each side independently. Should be back on the road in April.
