Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
ignition switch issue ???
« previous
next »
Print
Pages: [
1
Author
Topic: ignition switch issue ??? (Read 2543 times)
69z28fan
Newbie
on:
October 12, 2019, 08:16:34 PM »
I have a 1969 Camaro 4 speed, when engine is running, turning the key to off doesn't stop the motor. If the transmission is placed in reverse (locking steering column) or the emergency brake is on, the engine stops. Any ideas???
Tweet
Logged
dale68z
Newbie
Re: ignition switch issue ???
Reply #1 on:
October 13, 2019, 03:50:52 PM »
Is the engine running on/ dieseling when the ignition is off? Remove the wire to the + side of the coil. It should shut off immediately. If it does, then it is an electrical issue, if not it is a engine tuning issue
Logged
Hero Member
Reply #2 on:
October 14, 2019, 04:50:16 PM »
Have you done anything in the way of the alternator lately? If it's wired wrong, but car will continue to run with the ignition off.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
