Author Topic: Door Jamb courtesy light/key buzzer switch  (Read 2747 times)
vabeach56wagon
« on: September 18, 2019, 05:19:08 PM »
I have purchased and received a reproduction/replacement LH door switch. It has a rubber sleeve over the plunger. Is this simply to protect the plunger during shipment or was the sleeve installed originally? Doesn't seem to show up in any illustration in the AIM or elsewhere.
Thank you
Re: Door Jamb courtesy light/key buzzer switch
« Reply #1 on: September 18, 2019, 05:51:32 PM »
You mean like this? (See below)
Nope. No sleeve originally. Remove it and install. Or, if you're not concerned about "originality", you could probably just leave it on there. Probably won't hurt anything.
vabeach56wagon
« Reply #2 on: September 18, 2019, 07:07:40 PM »
Thank you...I'll remove it....may as well get some of the details right!
