Author Topic: Painted or not painted  (Read 2740 times)
x66 714
« on: September 05, 2019, 08:31:48 PM »
I have 3 bracket/clips on the engine I don't know if they had paint or not. They have paint now because that's what I did in 1982. Car is a 1969 ss396 325hp.
1) bracket that holds transmission cooler lines to pan rail.
2) bracket that holds battery cable to pan rail
3) bracket that holds plug wires to LH lower valve cover bolt. Valve covers are chrome.
    Bracket designed to divert plug wires from a/c compressor.
Thank you, Joe
Re: Painted or not painted
« Reply #1 on: September 06, 2019, 08:18:47 PM »
The bracket that holds the cable to the pan would be orange over sprayed if installed at Tonowanda.
x66 714
« Reply #2 on: September 08, 2019, 05:49:22 PM »
I thought about the information I was requesting by looking at other like parts I had laying around. What James said makes sense. That would also be true for the bracket that holds the transmission lines. I found one of those brackets that had no paint on the back side. I also noticed that I had to remove the lines to take that pan bolt out. Tonawanda would've known this engine would have an automatic behind by the "CJG" code. It would've had to be installed by the engine plant otherwise it may've also had a different bolt & the unknown line worker might've over tightened causing a pan leak. The transmission lines would've later been installed in that clip, closed & tab bent to lock.
The wire loom separator probably had no paint as it was on chrome covers.
Does all this sound logical?
Thank you, Joe
