Author Topic: What needs yellow zinc?  (Read 5587 times)
x66 714
« on: August 19, 2019, 12:30:04 AM »
I started a list of items that need yellow zinc for the 69. Am I missing anything?  Thank you, Joe
power brake booster
caliper mounts
smog check valves
master cyl lid
jack mast
bracket for valve below master cyl
diverter valve?
Re: What needs yellow zinc?
« Reply #1 on: August 19, 2019, 01:01:02 AM »
Rear seat belt retainer bolts that mount under the rear seat.
I think the jack mast can be with and without yellow zinc plating.
« Reply #2 on: August 19, 2019, 01:31:39 AM »
R/S tank vac switch mount.
Turn signal housing.
brake line rubber hose retainers.
Rad drain petcock.
Rear bumper lice plate light housing
Trunk latch activating pawl (??)
sway bar end link spacers
Heater hose corbin spring hose clamps (??)
more to follow (??)
x66 714
« Reply #3 on: August 19, 2019, 02:14:47 AM »
  The front inboard bolts are yellow. Outside one are chrome. At least that's the way they were on my car. thanks... Joe
x66 714
« Reply #4 on: August 19, 2019, 02:20:49 AM »
Rad drain petcock.
more to follow (??)
I'll look at some of those. Not an r/s. Forgot about t/s light & lic light. Brake line retainer I will examine. My latch was a combo of paint & spatter..Thank you, Joe
« Reply #5 on: August 19, 2019, 11:18:35 AM »
  I assume you're talking about 69? I just checked both my 67's and the front seatbelt bolts where chrome....one for the lap belt and one for retractor. I figured being they were visible is why they were chrome. Maybe 69 it was different?
  Pretty much other items mentioned already sounds accurate.  Drum brake components come to mind but I'm not sure which parts, if any.
« Reply #6 on: August 19, 2019, 03:49:59 PM »
"Drum brake components come to mind but I'm not sure which parts, if any."
Yes, the  anchor pin washer  is Zinc Dichromate,  it is the funky spacer with the ears. (For lack of a better description)
WorkinProgress
« Reply #7 on: August 19, 2019, 05:10:28 PM »
Joe,
I cannot remember if your car is a 4 speed. If it is, the 1st, 2nd and 3rd, 4th levers on a Muncie are yellow zinc.
Nothing on the sway bar link is yellow zinc.
                                                  - Warren
x66 714
« Reply #8 on: August 19, 2019, 05:56:38 PM »
Joe,
                                                  - Warren
TH400 Warren
« Reply #9 on: August 19, 2019, 11:57:54 PM »
Joe,
                                                  - Warren
It is very common practice to restore the 69 camaro orignal end link spacers to the zinc dichromate finish as it was originally.
photo of April 1969 build LOS car well preserved by grease revealing the "yellow Zinc"
JIM
JIM
Edgemontvillage
« Reply #10 on: August 20, 2019, 01:24:53 AM »
The radiator petcock is brass and not yellow zinc plated. Add to the list aluminum intake manifold carb mounting studs.
« Reply #11 on: August 20, 2019, 02:42:08 AM »
The Nut is brass, but the stem, barrel & wing nut are steel.
Detailed pic attached.
JIM
x66 714
« Reply #12 on: August 20, 2019, 11:01:24 AM »
I want to say thank you to everybody for their input....Joe
