a shudder or chattering on pull away as the clutch is engaging is almost always caused by the clutch itself. If the clutch is the problem resurfacing the flywheel and installing a new clutch is the solution. Clutch chatter is often worse when pulling away in reverse. A stock "OEM" type clutch is what I would recommend. Aftermarket performance clutches have a much higher tendency to chatter but may be necessary if the engine is highly modified. Engine tune up and mount problems usually will show up at other times as well as when the clutch is engaging. Rough idle, under load at low RPM, engine acceleration while standing are examples. A new clutch will chatter if it gets engine oil, transmission lube or grease used during installation on the disc. A new pilot bushing is a "must have" when replacing the clutch. These are my opinions based on experience and I hope they are a help.
I would agree 100% except - this is my 3rd clutch and 2nd flywheel with less than 1500 miles and virtually no change in the shudder -
At first I installed a new McLeod 20# flywheel with their twin disk RST setup - a lot of guys reported chatter so I wasn't worried - but couldn't live with it. I contacted McLeod and they sent me their Super Street Pro which has a ceramic pad on the flywheel side and organic on the pressure plate side - they said since it had such low mileage on the rST that I could easily get away without a resurface on a near new flywheel (we're talking less than 300 miles)
So - I put that clutch in - and made one error - I put the Throwout bearing on incorrectly, as in, the fork's retaining clip on the back side of the TOB instead of in between the flange - stupid mistake, and I'm not a rookie at this - - at first the clutch seemed smooth - but as it got warm, the TOB would not engage/disengage properly - and would make noise as I depressed the pedal -
SO - all that came out - and I learned that from the TOB not engaging the clutch properly, there was uneven wear on the flywheel - so I pulled all that off - had the stock 40lb flywheel Blanchard ground, and installed an OEM type (made by Ram) clutch - fully organic with a bit more holding power.
That started off seemingly smooth but still had a very slight shudder - I'm guessing nothing was solved but the problem slightly masked because fo the added inertia weight of the 40# wheel - - but now a few hundred miles in - its still shuddering on take off.
When I put the car back together last year - I did replace the motor mounts with new rubber mounts and I had an energy suspension poly mount for the trans - that's how the car sits.
tomorrow - I'm replacing the trans mount with an OE rubber mount - and I have 2 new Rubber motor mounts coming from HeartbeatCity - if the new mounts don't solve the issue - then it can only be the clutch fork or the bell housing - both of which are original and were not problematic before.
I SUPPOSE I goofed up the fork when I had the TOB on incorrectly - but I highly doubt that - I'm beginning to worry that I screwed up ANOTHER clutch with all this shudder - when its looking more and more like it never was a light flywheel or clutch problem to begin with.
UGH - back under the car we go
