Author Topic: "wanted Needle's in a hay stack " MY original 69 DZ 302 engine & part's  (Read 5940 times)
4ZNOW
  • You must be fast u were haulin when I passed you
I would like to see  :o if any one know's  if this engine is still around ? or a date correct   69 DZ 302 build date on cowl tag decoded is 69 sport coupe, norwood ,october-4th week,no trim code .   I believe that it is a Z28 car 3/8's fule line mount's on rear of frame for dual exhuast system . list of other parts wanted are the 4speed transmission, protect-o-plate,rear end , some interior part's.  the is   VIN# 9N532236  here's one more Z28 for the Registry  if you think you can help me thank's
« Last Edit: June 13, 2007, 04:24:37 AM by 4ZNOW »
4ZNOW -
The vin would be helpful since it is on the protect-o-plate.  There is also a partial vin stamped on the engine block and transmission case.  Posting your vin would increase your chances of finding your original parts, just watch out for fakes!   :)
