Author Topic: 1968 396 w/ AC; Fan & Clutch Help Needed  (Read 2255 times)
curtis0916
« on: August 01, 2019, 04:41:22 PM »
I have a 1968 SS396 with air conditioning and am attempting to determine the correct fan and clutch to use on it.  I did some research on this site, and believe the fan could be 3789562 or 3931002 (most likely 3789562), and that the clutch could be 3916139, 3916140, or 5329100.
I guess another question is if I would just need a 4-blade fan without a clutch?
I am a novice at this, and just want to make sure I have the correct parts on the car.  So any help/guidance would be greatly appreciated!!!
Curtis
Re: 1968 396 w/ AC; Fan & Clutch Help Needed
« Reply #1 on: August 01, 2019, 04:58:29 PM »
Curtis, did you read THIS? Also, do you have the 1968 Assembly Manual (A.I.M.)?
