Author Topic: '67 4-piston caliper pad rattle  (Read 5082 times)
70L34
« on: July 14, 2019, 07:19:10 PM »
I have a persistent issue on my '67 disc-brake GTO (sorry for the non-Camaro content but I know the system is essentially the same). I get a regular clicking noise from either one or both pads as they rock inside the caliper while driving. Is there any sort of anti-rattle spring, washer, etc that is supposed to be here to avoid this? The noise goes away completely when I apply the brake. Thanks!
Re: '67 4-piston caliper pad rattle
« Reply #1 on: September 22, 2019, 01:54:18 AM »
Tony,
no stock anti rattle springs... You can use the normal anti rattle plates which come with aftermarket pads.
Are the caliper numbers correct, I think the vette calipers will fit however I THINK the pads are longer.
Another - Have you checked the rotor runout if excessive maybe that could be the cause... pushing the pads back off the rotor too far, then allowing them to walk?
70L34
« Reply #2 on: December 23, 2019, 12:48:40 AM »
James / all,
Just to close the loop on this - I purchased Delco NOS pads and the rattle disappeared. Must have been poor dimensional control.
TangoBravo
« Reply #3 on: December 23, 2019, 01:43:22 AM »
There is a spring under each piston that lightly preloads the brake pads.
Kelley W King
« Reply #4 on: December 23, 2019, 12:35:21 PM »
vette calipers probably would not help. My 67 vette rattled on all 4 corners and drove me crazy. That brake goo you put on the backside did help.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
