Author Topic: 1969 Voltage Regulator Date  (Read 5644 times)
dbaker55
  • 412-477-0843
« on: July 14, 2019, 12:32:49 PM »
What would be the correct dated 515 voltage regulator for my 04C 1969 Z28? Is 4D too early?
1969 Z/28 Bought 2-8-2019
Spooky
Re: 1969 Voltage Regulator Date
« Reply #1 on: July 14, 2019, 04:34:04 PM »
9a 9b or 9c
« Reply #2 on: July 14, 2019, 04:50:48 PM »
There were almost 4.5 MILLION GM cars and trucks built in 1969 and 99 percent of those used the 1119515 regulator. Literally thousands had to be built every day so, with the exception of cars built very early in the month, most will be dated the same month as the build date of the car.  In your case, a 1969 Camaro assembled the 3rd week of April, 1969 would also have a April, 1969 regulator, so go with a 9D.
dbaker55
  • 412-477-0843
« Reply #3 on: July 14, 2019, 08:24:17 PM »
Thank You very much for the clarification. I meant the date 9D on the one I have. I thought it was possibly too late for a 94C built car.
Spooky
« Reply #4 on: July 14, 2019, 08:39:47 PM »
I was just going by what I observed on my car. It has it's born with reg dated 8L (dec of 68) on my 02B car built on feb 13th. I figured a month prior is good.
HOT3O2
« Reply #5 on: July 14, 2019, 11:41:41 PM »
If I’m not mistaken Spooky a 8L dated voltage reg. is Nov. not Dec.
Rick
69 RS/Z28
« Reply #6 on: July 27, 2019, 05:07:46 AM »
Most are the same month or the month prior.
67conv6cyl
« Reply #7 on: July 29, 2019, 12:51:48 PM »
Would the starter motor dates also be same month? I have a starter motor that is the correct part number however it is two months earlier than car build date.
« Reply #8 on: July 29, 2019, 05:54:14 PM »
Depends on which starter.
Starters were installed on the engine dress line at Norwood (or LA), and if we're talking about a common starter, like the one used on the LF7 and Powerglide, then it would probably be dated very close to the car's build date. However, if we're talking about an uncommon starter, like the Z28, it could be up to a few months prior to the car's build date.
Going by your signature, you have a 6 cylinder 67 Camaro, and since the 6 cylinder engines only accounted for (approx) 26 percent of sales that year, a 2 month spread probably wouldn't be that abnormal.
67conv6cyl
« Reply #9 on: July 29, 2019, 08:52:43 PM »
Thanks Ed, Yes it’s a 6...part #1107399 I am not sure if it’s a common starter or not.
« Reply #10 on: July 29, 2019, 09:12:21 PM »
According to the 1967 Chassis Service Manual (and Chassis Overhaul Manual), the 1107399 starter was used on all 1967 153 (4 cylinder) engines, 1967 194 (6 cylinder) engines with manual transmissions, 1967 230 (6 cylinder) engines with automatic transmissions and all 250 (6 cylinder) engines, so I'd say it was fairly common, but probably not common enough to have a huge stockpile on hand.
« Reply #11 on: July 31, 2019, 02:08:55 AM »
It's common. But I wouldn't sweat the date unless you stumble into a better one.
