Author Topic: gasket between the carburettor and the aircleaner  (Read 6878 times)
Nigel
« on: June 29, 2019, 01:32:40 PM »
Dear Sirs, Please can you clarify whether there should be a rubber gasket between the carburettor and the air cleaner on my 1968 L48 350CI Camaro RS/SS. The car has Rochester quadrajet and original aircleaner. Many thanks as always, Nigel
Re: gasket between the carburettor and the aircleaner
« Reply #1 on: June 29, 2019, 01:49:03 PM »
 Yes and it is a thick paper gasket and are still available from parts stores.
 I believe all engines used it from the 6 cylinder to the L78.
« Reply #2 on: June 29, 2019, 03:12:02 PM »
Depending on the manifold, make sure and read the following thread (other similar discussions over the years):
http://www.camaros.org/forum/index.php?topic=278.msg11624#msg11624
You'll need a SS "protection" gasket if your manifold has a "hot slot" in it. If you've already plugged ports, or someone else has, you use the fiber or sandwhich gasket.
Nigel
« Reply #3 on: June 29, 2019, 05:05:39 PM »
Thanks for the responses.
I am not a mechanic so I apologise for the questions but you mentioned the intake manifold  however the gasket I am after sits between the carburettor and the air cleaner.
The manifold I have is a standard cast iron manifold with oil fill.
Thanks you again in advance. Nigel
x66 714
« Reply #4 on: June 29, 2019, 05:44:00 PM »
Everything I ever worked on that had a carb had a thick paper gasket between the air cleaner housing & the carb to keep dirt out of the carb/engine......Joe
« Reply #5 on: June 29, 2019, 07:33:09 PM »
Fel-Pro Air Cleaner Gasket, 5-1/8" Diameter Fits Holley 4150 4-bbl & Quadrajet
Part Number: 375-60038
« Reply #6 on: June 30, 2019, 01:37:19 AM »
Got it. A little overboard in my first response (I had the situation of the hot slot in mind because of issues with my Quad equipped L48). Answer is a definite yes for the air cleaner-to-carb gasket, I always have had a handful of them in the garage stock.
Nigel
« Reply #7 on: June 30, 2019, 01:23:59 PM »
Many thanks to all who responded, I really appreciate it. Best regards, Nigel
Petes L48
« Reply #8 on: June 30, 2019, 07:33:29 PM »
I think it was around mid-model year 67 the gasket was added.  I believe indicated under UPC K19 or 24 in the AIM.
69pace
    • TeamCamaro - Moderator
« Reply #9 on: July 03, 2019, 10:26:37 PM »
Often I find it is either missing or sometimes heat-welded to the bottom flange of the air cleaner housing, so you may it is missing but its not.
But as stated available over the counter. Cheap too.
https://www.jegs.com/i/Fel-Pro/375/60038/10002/-1
Brian
« Reply #10 on: July 04, 2019, 01:08:43 AM »
I think my car had a carb/ac gasket cut from a piece of corrugated cardboard on it when I bought it in 1976... I'm pretty sure the same 'gasket' is still on it today..  :)
PHAT69AMX
« Reply #11 on: July 07, 2019, 07:56:03 PM »
imho they also often get blown off and lost when doing tune-up stuff with the air cleaner off and revving motor.
Old notes on-hand say the 5-1/8" Air Cleaner Gasket is Fel Pro # 60038 and maybe # 13-6516
« Reply #12 on: July 22, 2019, 05:52:09 PM »
FWIW The original factory gasket is a natural or tan color the reproductions/what is currently available is black or dk gray.  - I had a point deducted for the wrong color at he NCRS national show.
