Author Topic: Correct Hurst Shift rods  (Read 3712 times)
R68GTO
« on: May 14, 2019, 12:52:22 AM »
Are the factory shifter linkage rods for a Hurst Competition Plus (with Muncie) the same between big block and small block applications?  I'm looking to source a set of originals and see that the repro guys list them as separate part numbers so am assuming they are different.  If different, is it because there is a different offset in the engine position between big and small block applications?
m22mike
Re: Correct Hurst Shift rods
« Reply #1 on: May 14, 2019, 01:23:31 AM »
R68GTO
« Reply #3 on: May 16, 2019, 02:47:51 AM »
Thanks guys!  The search is on!
