Author Topic: Drop of oil at the steering column boot  (Read 5398 times)
camaronut
« on: May 04, 2019, 11:33:48 PM »
Interesting......i was vacuuming out my 69 Camaro and i noticed a drop of oil was on the steering column round boot that meets up with the plastic firewall guard.  I have console gauges and looked at my nylon oil line, but it looked good...no leaks...
Where would the oil come from?  Any thoughts?
Thanks...
Re: Drop of oil at the steering column boot
« Reply #1 on: May 04, 2019, 11:39:24 PM »
What kind of brake fluid are you using ?
camaronut
« Reply #2 on: May 04, 2019, 11:42:59 PM »
DOT 5 - Silicone...
Good thought...I have power brakes though....
« Reply #3 on: May 05, 2019, 12:09:38 AM »
My first impression is brake fluid coming out of the cylinder rear and telegraphing down the brake pushrod and dripping onto the steering boot
Danzo
« Reply #4 on: May 05, 2019, 12:20:19 AM »
Agree with Mike. Take a look above the boot.
Doc.
camaronut
« Reply #5 on: May 05, 2019, 12:40:31 AM »
Just checked......dry as a bone...
Good call though....
« Reply #6 on: May 05, 2019, 12:50:10 AM »
Transmission oil making its way up the speedometer cable side screwed into the dash?
camaronut
« Reply #7 on: May 05, 2019, 01:08:57 AM »
It almost had the consistency of motor oil....hence the oil line suspicion.
You would think if the oil line was leaking I would be able to see / smell it.....ehh...whatever.  There's no oil on the carpet......anywhere.
I'll have to keep an eye on it...thanks.
« Reply #8 on: May 05, 2019, 01:19:50 AM »
On my 67 I keep a piece of a wee-wee pad under the oil gauge in the console and check it from time to time. If it leaks then the pad will absorb it instead of the rug. I get to it by removing the shifter bezel.
camaronut
« Reply #9 on: May 05, 2019, 01:28:44 AM »
I'll do that.....thanks for the idea.
« Reply #10 on: May 05, 2019, 01:58:42 AM »
Maybe speedometer cable lube, if you've done any recent maintenance in that area?
olddragracer
« Reply #11 on: May 05, 2019, 02:09:31 PM »
If the car has an automatic transmission there is a good chance that it is transmission fluid coming up the cable. On the 350 and 400 transmissions you would need a new seal in the speedo adaptor and be sure there is not a groove worn in the speedo driven gear where the seal rides. On a powergide be sure the speedo gear adaptor has a seal, some do not have a seal. If it is a manual transmission it is less likely to be the speedo adaptor seal but still possible.
camaronut
« Reply #12 on: May 05, 2019, 03:27:12 PM »
I'll check that.....thanks!!!
