Author Topic: 69 Coil Wire Issue  (Read 10670 times)
crossboss
  • ^ New engine project
Re: 69 Coil Wire Issue
« Reply #15 on: May 01, 2019, 10:19:55 PM »
There were GM transitor ignition set ups but I do not think anyone repops them are the originals are unobtainable price wise.
Yes, correct very rare. This is why I did not mention them. I believe 'Most' were installed on Corvettes and some race versions. Weren't they also used on tach drive set ups(?).
1968 Olds 442 W-30
mikefam
« Reply #16 on: May 12, 2019, 05:58:17 PM »
One way to compensate for the resistance in the car's primary wire is to buy a coil with less primary resistance eliminating any re-wiring.
The pertronix pickup needs to be used with the correct ignition coil resulting in the correct resistance in the primary circuit. A pertronix technician will be able to guide you in choosing the right coil.
If memory serves me, I had to replace a 3 ohm Mallory coil with a 1.5 ohm coil in my stock 68 but then my memory kinda sucks these days.
Mike.
68 Convertible w/327 275hp donor engine from a 67 Impala and TH350
mikefam
