Author Topic: 69 BB 4 blade fan bolts  (Read 3719 times)
Danzo
« on: April 09, 2019, 12:28:18 AM »
Guys, looking for info/pictures for the bolts that hold the 4 blade fixed fan to the water pump. Head markings, length , etc.
Thanks, Doc.
Danzo
Re: 69 BB 4 blade fan bolts
« Reply #1 on: April 14, 2019, 12:15:53 PM »
Anyone?
x66 714
« Reply #2 on: April 14, 2019, 12:36:51 PM »
Doc, I did a little research on the spacer, I found it to be part number 3927792, 1". It was used on all 1969 V8 engines that didn't have a fan clutch. Researched the part number in the catalog but find no listing of the bolts. Knowing that it's not big block only might help others to look....Joe
Found some more info. Bolt was a 9427927 which was a 5/16-24x2". Used a lock washer also.
Now you need the head marking
« Last Edit: April 14, 2019, 01:43:01 PM by x66 714 »
« Reply #3 on: April 14, 2019, 05:10:51 PM »
Doc, picture of what our bolt heads are on our 69 L78 Nova which did not utilize a fan clutch from factory. Had to use a light and mirror to get a picture.
Danzo
« Reply #4 on: April 14, 2019, 06:21:55 PM »
Joe and Chick,
 Thank you very much!
Doc.
x66 714
« Reply #5 on: April 14, 2019, 07:03:36 PM »
The ones for mounting the fan clutch to the pump also have that same head...just didn't know about 4 blade...Joe
Danzo
« Reply #6 on: April 15, 2019, 11:36:13 PM »
Any big/small blocks out there with a different head marking than Chick's?
Thanks, Doc.
