Author Topic: Standard 3 speed Saginaw  (Read 2939 times)
67conv6cyl
« on: March 27, 2019, 08:56:05 PM »
Does anybody know what a standard Saginaw 3 speed floor mounted shifter factory back up switch looks like?....not the HD trans
Jek9016
Re: Standard 3 speed Saginaw
« Reply #1 on: March 28, 2019, 05:02:08 PM »
Not sure, but if you are experiencing trouble I switched over to an aftermarket Hurst back up light switch.  It was easy to install and works well.  I have a Saginaw 4 speed, but believe the same part will work with any hurst shifter
olddragracer
« Reply #2 on: March 29, 2019, 07:16:47 PM »
The Saginaw 3 speed backup light switch is the same as Saginaw and Muncie 4 speeds for 67 and 68. The bracket that mounts the switch to the side cover is different than the  Muncie 4 speed. The 1/8" rod that hooks the switch to the 1st and reverse lever is unique to the 3 speed Saginaw floor shift. I hope this info helps, I am working from memory.
67conv6cyl
« Reply #3 on: March 29, 2019, 09:15:27 PM »
I am looking for a original picture if anybody has one or original part number.
