Author Topic: Correct color bolts for Steering Box  (Read 20833 times)
BillG
Re: Correct color bolts for Steering Box
« Reply #15 on: August 21, 2019, 03:31:11 PM »
03B 69 Pace car.  Shouldered bolts.  No Saginaw logo.
Bill Garrett
Edgemontvillage
« Reply #16 on: August 21, 2019, 07:02:46 PM »
Bill, does the logoless box cap have a a Julien date stamped on it? If so what’s that date? Is yours a power steering box original to the car? What’s the casting date of the housing?
BillG
« Reply #17 on: August 22, 2019, 09:07:44 PM »
not sure if this is a julian date or not;  130   3   and  7812145.  do those numbers mean anything?
Bill Garrett
Edgemontvillage
« Reply #18 on: August 25, 2019, 05:09:55 AM »
Here's my freshly restored 354 of 1968 box with non-shouldered bolts and lock washers.
Edgemontvillage
« Reply #19 on: August 25, 2019, 05:43:20 AM »
Bill that decodes to the 130th day of 1973 or May 10, 1973
BillG
« Reply #20 on: August 25, 2019, 05:34:48 PM »
Thanks Lloyd and, nice work!
Bill Garrett
« Reply #21 on: August 25, 2019, 08:13:24 PM »
I'm a little surprised that GM/Saginaw used a lock washer to bear against the aluminum housing cover... as it's general practice in aerospace *(and automotive?) not to do so..
Lockwashers should never be used under the following conditions:
1. With fasteners to primary or secondary structures.
2. With fasteners on any part of the aircraft where failure might result in damage or danger to the aircraft or personnel.
3. Where failure would permit the opening of a joint to the airflow.
4. Where the screw is subject to frequent removal.
5. Where the washers are exposed to the airflow.
6. Where the washers are subject to corrosive conditions.
7. Where the washer is against soft material without a plain washer underneath to prevent gouging the surface.
« Reply #22 on: August 25, 2019, 08:35:21 PM »
 I believe the Muncie transmission to bellhousing bolts use split ring lock washers under them with no flat washer.
BillG
« Reply #23 on: August 26, 2019, 09:30:18 PM »
I've been looking for an original 69 Saginaw gear box cap since the one on my car is incorrect but they are nowhere to be found.  I always thought more money could be made just parting a car out than selling the whole car.  The search goes on!
Bill Garrett
« Reply #24 on: August 27, 2019, 12:39:54 AM »
LOS 04C Pace car, fluffed
Lloyd that looks spectacular, is that finish also a product of that fancy hydro blaster?
JIM
« Reply #25 on: August 27, 2019, 04:04:21 AM »
AG is the broadcast code for a Camaro power steering box, fwiw.
Edgemontvillage
« Reply #26 on: August 27, 2019, 05:01:45 AM »
Thanks Kurt, I didn’t know that.
Edgemontvillage
« Reply #27 on: August 27, 2019, 05:09:23 AM »
JIM
Thanks Jim. I’ve produced a similar case finish using either vapor blasting or electrolysis. Neither will produce that “fresh cast” look on its own. Starting with a clean and rust-free case, following electrolysis or vapour blasting I heat treat it. Details are in my build thread on TC.
Edgemontvillage
« Reply #28 on: August 28, 2019, 04:21:56 PM »
Jim, the date stamp on your PS box cover appears to read 80th day of 1969 (March 21, 1969) and non-shouldered bolts.
Untitled by Lloyd Costley, on Flickr
« Last Edit: August 28, 2019, 05:02:31 PM by Edgemontvillage »
67CruiseMaster
« Reply #29 on: August 28, 2019, 04:51:00 PM »
Lloyd would you mind posting the link on TC for that. I'd be really interested in reading your procedures for box resto.
Scot
67 Tuxedo Black Convertible.
