Author Topic: 1969 wiper switch repair  (Read 6359 times)
camaromikey
« on: March 05, 2007, 09:31:23 PM »
does anyone know of a way to repair the wiper switch mounting on the 69 dash without drilling holes and also repairing the steering column cover at the buttom. the rest of the dash is in prefect shape just those two areas. thank everyone you guys have been great help.
Re: 1969 wiper switch repair
« Reply #1 on: March 17, 2007, 03:08:32 AM »
I've repaired them using 2 part epoxy for the wiper switch. Take a screw, put a tiny bit of oil on it, then position it in place and build up the boss around it. Just remove it after it cures and you're set. Only trick is getting the right boss height.
Plastic weld (aka solvent) for the missing tabs.
camaromikey
« Reply #2 on: March 17, 2007, 06:30:35 AM »
Thanks for the info. CRG has been a big help.
